It is currently Mon Feb 18, 2019 12:36 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Dec 05, 2007 8:56 pm
ring and pinion -- 1st - 2nd - 3rd - 4th
std type 3 -- 3.87 -- 3.80 -- 2.06 -- 1.26 -- 0.88
performance -- 3.88 -- 3.78 -- 2.06 -- 1.48 -- 1.04
could of had 1.14 4th but would of reduced top end too much i thought.
once i change into to 3rd gear it should pull pretty well with less rev drop
http://www.vwspeedshop.com/store/product.php?productid=847&cat=376&page=1 :smt003
PostPosted: Wed Dec 05, 2007 9:01 pm
From ass to gears :smt017
Covinless!
PostPosted: Wed Dec 05, 2007 10:04 pm
:smt017 :smt017 :smt017 :smt017 :smt017 :smt017 :smt017
PostPosted: Wed Dec 05, 2007 11:50 pm
Danny. Are you sure those gears for 4th are correct because that would mean your new gearbox ratio (4th 1.04) will be reving higher in 4th at a given speed compared to the standard T3 ratio (4th 0.88) :smt017 Have I had to much Rum tonight or have I been breathing in to much 2 Pack paint fumes today :smt017 :lmao
PostPosted: Thu Dec 06, 2007 5:03 pm
yes they are correct darren .the 3rd and 4th are close ratio.thats what i wanted as most of my driving wont be motorway.i wanted something quick through the gears.
the standard type 3 box at 4000 revs will give me 87mph in 4th
the close ratio box i have at 4000 revs will be at 74mph in 4th
john has .82 final drive so at 4000 revs will be at 94mph in 4th
i will top out at 6000 revs at aprox 95mph .so will avoid speeding ban lol.
the covins scary to drive over 100mph.had it at 110mph and was dicing with death :smt119 .the gear ratios i have should suit what im using it for and where i go..
will be able to do a comparison test accuratley when johns covin on the road as will be the same engines. :smt012
your onto spraying are you matey.cant wait to see the type 3 resto pics :smt012
PostPosted: Thu Dec 06, 2007 5:24 pm
:smt003 Thank god for that.... I thought I was cracking up there :lmao
Should be much better through the gear m8, I could do with 3rd gear changing because it's not a good ratio for the Turbo Engine so going from 2nd to 3rd gives lots of turbo lag until the revs pick up more :smt013
PostPosted: Thu Dec 06, 2007 6:21 pm
MY 8VALVE SHULD BE GOOD FOR LOW END GRUNT SO SHOULD BE ABLE TO KEEP IT SPINNING.ANOTHER IMPROVEMENT IS A QUICKER AND SMOOTHER GEARCHANGE.ID LIKE THE DADDY OF ALL VW GEARSHIFTS A GENE BERG UNIT WHEN FUNDS PERMIT.
http://www.skintaracing.com/shop_viewproduct.asp?itemcode=150
PostPosted: Thu Dec 06, 2007 6:47 pm
Re: Nice ass.
How about this one? I like the hardcore look of the turbos underneath.
PostPosted: Thu Dec 06, 2007 6:53 pm
Very Nice :smt012 :smt012 :smt012
PostPosted: Thu Dec 06, 2007 8:32 pm
now thats a beast !!!!
PostPosted: Thu Dec 06, 2007 8:33 pm
thanx andy i see now :smt012 ummm looks a bit mix and match for my taste
a childs laughter is gods hand on this cruel world
PostPosted: Thu Dec 06, 2007 8:38 pm
doros911 wrote:
Re: Nice ass.
Now THAT is Very nice :smt012
