It is currently Sun Aug 25, 2019 2:46 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Jan 22, 2008 7:57 pm
look at the picture of the gear stick and the plate that holds it to the tunnel, is the front bolt missing ?
death. the working mans friend.
PostPosted: Tue Jan 22, 2008 8:17 pm
It is Andy, id removed it, though now ive moved it a bit it feels alot better, im wondering if through use it had moved slightly, ive put a shakeproof washer on it to see if it makes a dfifference.
Ill get a pic of the box tommorrow, but yes that pic i posted is of the side of the box with the linkage on it
Nemesismedia.co.uk
PostPosted: Tue Jan 22, 2008 9:13 pm
In that case it looks like you've got a T25 Bus Box fitted rather than a T1 or T3 item :smt017 I've never seen one fitted to a covin before due to the amount of work involved. It's a strange one this. . . . .
PostPosted: Tue Jan 22, 2008 9:17 pm
i COULDNT MAKE THE PICS OUT ,DOESNT LOOK LIKE A STANDARD BOX. :smt017
PostPosted: Tue Jan 22, 2008 9:39 pm
Would it be a good or bad thing if it had one :smt017
And would there be a possability that it could be changed for a 5 speed :smt003
Nemesismedia.co.uk
PostPosted: Tue Jan 22, 2008 10:42 pm
Unless it is a 5 speed that's fitted and been modified I can't see why anyone would use this Box because it's designed for a Van or Camper with lower gear ratios :smt017 As I said, it's a strange one this . . .
PostPosted: Tue Jan 22, 2008 11:07 pm
Ive go no idea, i was told by Matty it was only a 4 speed box though. Is it any stronger do you know? :smt017
Nemesismedia.co.uk
PostPosted: Wed Jan 23, 2008 12:01 am
It's probably a stronger box as it's made for Camper vans etc but I'm not sure how good the gearing will be. Driving it will be the only way to tell if the gearing is ok :smt012
PostPosted: Wed Jan 23, 2008 6:34 am
I was told it was a 4 speed box 22222222222 it drives in the gears fine Ive used my Sat Nav and it pulls to over 100 mph no probs
PostPosted: Wed Jan 23, 2008 10:06 am
That's good to know Matty, it must be a T25 4 speed unit in that case and might even have had the final drive ratio changed who knows. As long as it does the job there's no problem with it :smt012
PostPosted: Thu Jan 24, 2008 1:07 am
Not the best, but some pics of the box.
Far out:
Underneath:
Nemesismedia.co.uk
PostPosted: Thu Jan 24, 2008 2:05 am
Very odd :smt017 I still think it might be a T25 box unless there's a 4 speed Porsche box like this :smt017
Your gear selector looks like it's to the right of the drive shaft. The "T" shaped affair which conects to the gear selector on gearbox and also goes down the transmision tunnel to the gear stick. So check to see if this is all conected :smt012
I've found a picture that shows the location of the gearbox code number so if you have a good look we might be able to identify this box
