It is currently Sun Jan 21, 2018 2:03 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Dec 06, 2007 8:55 pm
Covin wrote:
doros911 wrote:
Re: Nice ass.
How about this one? I like the hardcore look of the turbos underneath.
Now THAT is Very nice :smt012
re very very very nice, big and wide and all offf side, mmmmmmm :smt012
p.s i do like the bonnet on the red rsr
:smt012 :smt012 :smt012 makes me think a bit, :smt012 :smt003 :smt003
PostPosted: Thu Dec 06, 2007 9:16 pm
that bonnet woul be ideal for a radiator heat outlet.always like the way lotus elise have thiers.
PostPosted: Thu Dec 06, 2007 9:22 pm
I agree, it would also give some good downforce to the front end at speed which would help stability.
Wouldn't cure the airlock problems of front mounted Radiators when using standard water pumps though :smt018
PostPosted: Thu Dec 06, 2007 9:27 pm
SO IF AN ELECTRIC WATER PUMP WAS FITTED ..WHAT SORT OF FLOW RATE WOULD IT NEED :smt017
 Post subject: re flow rate,
PostPosted: Thu Dec 06, 2007 9:31 pm
you got to make sure you get the size of pipe too mate, to shift the water by volume,, rather than speed, look at seans camper with subi lump in it, the rad is at the front, and that engine wasnt designed to have the rad, 10 foot away, how does he manage it, volume, the pipe size is massive compared to some front rad covins, :smt012 :smt012 :smt012
PostPosted: Thu Dec 06, 2007 9:32 pm
ILL HAVE TO FIND OUT WHAT HES USING. :smt012 SO IF I RUN A COUPLE OFF DRAINPIPES EITHER SIDE OF MY SILLS ILL BE SORTED :lmao
 Post subject: re pipe
PostPosted: Thu Dec 06, 2007 9:35 pm
danny the rad and the pipe work i think is the original vw t25 system, i might be wrong but it looks pretty standard, and seems to work well. after all he went to france up and down them hills, you aint telling me you could do that danny, at momemnt :smt012 :smt012 , but also the rad mounted in the back has now been sorted thanks to darren :smt012 :smt012 so you dont need it at the front , i know what you mean though mate, better air flow at all speeds
PostPosted: Thu Dec 06, 2007 9:40 pm
IVE NOT HAD PROB WITH RAD IN COVIN.DOES GET HOT WHEN IN TRAFFIC BUT FAN SORTS IT.TWIN FAN WILL HELP.WILL HAVE TO DO SOME TESTS ON SUMMER.ILL FIT TEMP SENDER THE RAD END AND COMPARE TO ENG SIDE.
 Post subject: re dannies post
PostPosted: Thu Dec 06, 2007 9:47 pm
:smt012 good idea mate, that will show exactly what is happening :smt012 :smt012
PostPosted: Fri Dec 07, 2007 2:25 pm
My camper uses standard t25 plumbing ie about 40mm flow and return pipes with 15 mm heater pipes. The rad is huge though and is well positioned for good air flow, also the rad sits at the highest point with a bleed valve at the top so no air lock issues. Ive done 4 trips abroad some 12000 miles France Italy Switzerland etc etc in extremes of temp ( one memerable day in Saint Tropez )jeez it was hot, Ive towed a trailer with cars and campers on hundreds of miles and never had any cooling issues, This has sold the idea of a front rad in the covin for me, however I wont get as good as air flow !!! and the rad wont be the highest point so may have bleeding trouble unless I hoist the front end up when bleeding. Also overcooling can cause trouble so good stat control is essential. Im planning on using the same cooling route design as my van conversion making use of t25 reservoir and expansion tanks. The subaru stat relies on heater circuit feedback so if your heater matrix closes off you lose stat control !!!!!! unless you create a bypass loop with a small orofice in ..... Proper understanding is key to good running temp especially with flat alloy engines which will damage in seconds. will let you know how I get on with the covin install still convinced it will be fine :smt012 :smt012
PostPosted: Fri Dec 07, 2007 4:04 pm
great stuff ,cheers sean :smt012
 Post subject: re seans post
PostPosted: Sat Dec 08, 2007 2:10 pm
:smt012 nice one sean, you see chaps the rad at the front can be done, but it has to be done right, at the back is a bit more forgiving i think ,
by the way anyone still fancy the rear lights,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=004
i guess thats a no then, :smt016 :smt016
