It is currently Sat Oct 20, 2018 6:40 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Fri Nov 02, 2007 8:59 pm
Fuel enders on these things are weird mind and rather expensive :smt005
Rear seats are Porsche 911 ones so check out eBay :smt017 Come to think of it I might have a set of Black cloth ones in the loft that I'll sell but
I'll have to check on that.
PostPosted: Fri Nov 02, 2007 9:03 pm
thanks Darren
perhaps i will just carry a petrol can lol.
Do i need to put an adittive in with the juice?
ImageMarky - Plastic Fantastic!!!!!
PostPosted: Fri Nov 02, 2007 9:10 pm
Your engine will be fine using Unleaded so no need for any additives :smt012
The fuel sender looks like a tall aluminium can and inside it has a float that runs up and down two very fine wires, common fault is these wires snap OR they snap when you take it apart :lmao Just be aware it's fragile so remove the can bit with care so you can inspect the wires are intact, if there ok it might just be a wiring fault on the gauge.
A can of fuel stored up front is always a good idea if the fuel gauge is faulty.
PostPosted: Fri Nov 02, 2007 9:14 pm
cheers sounds like fun :lmao
did u see the carbs on ebay 170164276370 are these worth a go?
PostPosted: Fri Nov 02, 2007 9:19 pm
I've replied to your thread on that subject, not worth the trouble m8 :smt018
