It is currently Tue Jan 22, 2019 1:36 am
Post new topic Reply to topic  [ 11 posts ]
 Post subject: MY COOLING SYSTEM
PostPosted: Fri Mar 30, 2007 9:34 pm
[img]anyhow heres some pix of my cooling system
HERES THE CUT OUT FOR RAD WHICH IS NEARLY WIDTH OF THE RADIATOR
THE RADS AN AUDI UNIT,CANT FIND INFO ON WHAT MODEL AS CODE IS DISCONTINUED.THE INLET AND OUTLET ARE SAME SIDE .
[img][img]http://i57.photobucket.com/albums/g216/dannycovin/Picture298.jpg[/img]
I HAVE TWO SUPPORT BRACKETS RUNNING FROM BEAM ATTATCHED TO BTM OF RAD,WHILE THERE ARE TWO MOREBRACKETS UNDER BUMPER FOR TOP SUPPORT.
[img][img]http://i57.photobucket.com/albums/g216/dannycovin/Picture299.jpg[/img][/img]
[/img]
[img]HERES THE RADIATOR SLIGHTLY TILTED FORWARD.NEED TO FIX FAN SWITCH SENSOR EVENTUALLY,BUT HAVE WIRED SWITCH IN CAB TO PUT IT ON WHEN NEEDED FOR NOW.
[img][img]http://i57.photobucket.com/albums/g216/dannycovin/Picture293.jpg[/img]
HERES THE BLEED PIPE UNDER THE BONNET WHICH COMES OUT THE TOP OF THE RADIATOR.
[/img]Image[/img]
PostPosted: Fri Mar 30, 2007 9:39 pm
[img]HERES THE BACKEND PIPEWORK WITH THE GOLF WATERPUMP HOUSING IN VIEW.THE PIPE WORK WORKS ITS WAY INTO THE TUNNEL ,OUT THE BULKHEAD SECTION AND THROUGH THE BEAM TO THE FRONT.
[img][img]http://i57.photobucket.com/albums/g216/dannycovin/Picture311.jpg[/img]
HERES THE HEATER BOX UNDER THE DASH WITH THEM COPPER PIPES WHICH GIVE THE HEAT IN THE SUMMER
[img][img]http://i57.photobucket.com/albums/g216/dannycovin/Picture314.jpg[/img]
THE HEATER CONTROL LOOKS JAPANESE..ANSWERS ON A POSTCARD :lmao
[img][img]http://i57.photobucket.com/albums/g216/dannycovin/Picture319.jpg[/img][/img][/img]
 Post subject: re dannies heater
PostPosted: Sat Dec 08, 2007 2:38 pm
like the heater box danny, you still have it fitted dont you, or have you changed that too, :lmao :lmao what is it out of, as it looks very compact mate, and the controls very neat :smt012 :smt012 :smt012 :smt003 :smt003
PostPosted: Sat Dec 08, 2007 4:08 pm
its japanese i think.Its still in there.the center consul will be butting up to it.i then want to make apanel at the side and carpet it to clean up the look. :smt012
 Post subject: re dannys post
PostPosted: Sat Dec 08, 2007 11:21 pm
:smt012 great stuff mate, hope your nearly there mate, bet your ready for a run up the road, p.s the 911 back box does sound so good on your car :smt012 :smt012 sweet
PostPosted: Sun Dec 09, 2007 5:46 pm
not yet no lol.waiting for some new leads i ordered and going to buy new coil with high output .then its new dizzy cap ,rotor arm and should run sweet.
havent done much as the weathers been a mare.today was sunny but been in loft pullin out the christmas decorations and tree.
 Post subject: festive frolics
PostPosted: Mon Dec 10, 2007 11:11 am
:smt012 yeh bit nithering aint it, we too been doing the loft box shuffle, :smt013 :smt013 :smt013 same shit differant year :smt012 :lmao :lmao :lmao
PostPosted: Mon Dec 10, 2007 11:26 am
Cold ?... Your all tarts :smt016 I'm still working outside on that T3, every days the same and I'm sick as a chip :smt005 :lmao
PostPosted: Mon Dec 10, 2007 11:40 am
:smt012 yeh its good being a warm tart :smt012 :lmao :lmao :lmao
 Post subject: send heat
PostPosted: Tue Dec 11, 2007 4:10 am
:lmao :lmao talking of heat, bliddy freezzzzzzing here in canada, - 5 & snowing.
anybody got any ideas to assisting on keeping me & julianna warm.
i hear the native indians down the road are sharing a blanket to keep warm, :lmao :lmao :lmao :smt040 :smt114 :smt114
long turn end pedal fever suferer
 Post subject: re pauls post
PostPosted: Tue Dec 11, 2007 1:02 pm
:smt012 hi mate, you both well and cold, i can sort somthing out to keep julianna warm, but your gunna have to freeze your ass off :smt012 :smt012 :lmao :lmao :lmao :lmao
