It is currently Fri Apr 26, 2019 11:43 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Feb 05, 2009 11:06 am
Yes, RS wing looks good and so does the panel and door gaps. Looks to be a very well built Covin :smt012
PostPosted: Thu Feb 05, 2009 1:17 pm
With all the snow here its good to look at a sunshine yellow covin surrounded by blue sky, :smt028 very nice
PostPosted: Sun Nov 29, 2009 6:34 am
http://img402.imageshack.us/img402/3663 ... entipm.jpg
Took another pic today after a test drive. Now fitted with a Subaru EJ22 motor.
PostPosted: Sun Nov 29, 2009 10:22 am
Mark,
Looks good :smt012 (Bastard! :smt093 ) going for probably the same colour (GMH :smt077 Devil Yellow), only you beat me to it (Bastard! :smt093 ). Just doing my sons ute now in that colour (2-pak), long winded process as it was initially a write off, so lots of body work. Always something jumping in ahead of the jobs you really want to do!
Did you manage to hang onto the MR-930 plates? As if you let them go there is now an annual charge........
Looking forward to some engine pics/details as I've also been setting up to drop a Subi EJ20T or EJ20TT into the Covin, just want to upgrade brakes, Wheels & susspension first (also slowly fitting a C2 update).
I've collected all the bits, its just the time thats been eluding me.
:smt039 SeeYa, :smt039
Rainer
50+ years ago I started with nothing, I still have half of it left..............
PostPosted: Sun Nov 29, 2009 10:33 am
Looking very good :smt004
You'll have to post more pictures and info on the new engine though :smt012
PostPosted: Mon Dec 14, 2009 2:16 am
ImageImage[/img]
PostPosted: Mon Dec 14, 2009 2:18 am
PostPosted: Mon Dec 14, 2009 2:20 am
PostPosted: Mon Dec 14, 2009 2:28 am
More pics. The Subaru has been in a few weeks now and is going great. As you can see the radiator is behind the motor, had a few say it wouldn't work but it seems fine. Its the radiator out of the subaru with thermo fans that cut in at 85 degrees. It does get a little warm at speed on the highway(100) but cools down when I slow down, runs about 80 around town. As you can see I had to chop the sump about 45mm to give some ground clearance.
PostPosted: Mon Dec 14, 2009 11:03 am
Great stuff :smt012
I also found the temperature got higher at speeds with radiator mounted in different locations in the rear and then cooled down as I backed off a bit. It was fine around town though.
I finally cured this problem by fitting the radiator flat in the left hand side of the engine bay and also added a long, thin oil type cooler behind front bumper as part of the cooling system and that cured all temp problems in hot weather. Might be worth you doing the same, because the rad in the rear just doesn't get quite enough airflow on it's own to cope with high speed in hot weather.
Looking good though :smt004 Which Subaru engine have you fitted ?
PostPosted: Mon Dec 14, 2009 9:48 pm
:smt012 mmmmmmmmm subi doobi dooooo :lmao :smt012 great stuff mark. cracking job there. bet its a beast to drive, hows the front end , twitchy at all on cornering under power or do you have a bag of sand in there ??? :smt003 :smt003 , that rear wing really nice mate :smt004 :smt004 :smt004 :smt004 tinker tinker :lmao :lmao
PostPosted: Wed Nov 24, 2010 10:25 am
Just found some pics of my old speedster so I thought I'd post.
Users browsing this forum: Bing [Bot] and 3 guests
