It is currently Sun Jun 24, 2018 6:01 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Tue Mar 17, 2009 10:33 am
How close is Larne Ferry to you ? This could be an option because the Ferry from Larne to Fleetwood gets you much closer to shows.
Travel from Fleetwood to the following shows.....
Stoneleigh 150 miles.
Newark 152 miles.
Run to the hills (Derbyshire) 129 miles
Would this be any good ?
PostPosted: Wed Mar 18, 2009 6:48 pm
Thanks Darren. Thats other options.
Paul 106
PostPosted: Thu Mar 19, 2009 12:18 am
There is always tatton park in august.This is a classic car show but a good one.Went with Mark and sharron last year.If you got a ferry from belfast to liverpool its only about 40 miles away to show.The only thing is the ferrys 7.5 hrs but its not driving .Hopefully mark and sharron are comming again and maybe some other members.John should have his covin there so thatll be 3 including mine and marks.Just a thought :smt012
PostPosted: Thu Mar 19, 2009 9:18 pm
:smt012 excelent show .and the company couldnt get any better either :smt012 , and will do again matey. should get a club stand and make a weekend of it :smt020 :smt019 :smt015 :lmao
PostPosted: Fri Mar 20, 2009 1:05 am
Yes sounds a good idea as its a 2 day event :smt012
PostPosted: Fri Mar 20, 2009 9:16 pm
:smt012 is there another event on at that time danny, ???? this one is a monster though and i wouldnt miss it for the world.... unless i didnt get a tickett that was :smt009 :smt009 :smt009 :smt012 i think its 40 mins from us and a nice drive there too, never seen so many stalls selling everything :smt012 :smt012 and so many good cars and club stands, :smt012 :smt012 :smt012 i think its a must danny . :smt012 :smt012
PostPosted: Fri Mar 20, 2009 10:45 pm
Theres nothing else on i can see.The tatton classic show is on twice a Year
may 30-31st and Aug 22-23rd.Think august best if you want to enter as its populer and fills up quick.best ask whos going so can book in cars or club
PostPosted: Wed Jun 24, 2009 11:50 am
Dreamer-Non Member
Dreamer-Non Member
Hey Paul,
I just bought my first covin and I want to do the same conversion you have with the impreza option.
Could you do a post on how you did the process?
Pitfalls? Things you would have done differently?
Basically my plan is to use the impreza ecu shafts suspension struts - basically the car being an impreza RWD with the covin shell
what gearbox have you used?
PostPosted: Wed Jun 24, 2009 12:47 pm
Hi, that really isn't going to be possible I guess for you without major fabrication work .I only fitted the Suby motor to the T3 vw gearbox with an engine adapter plate from Kennedy Engineering, California on the covin chassis. If you read my thread you can see the build process as it went along. If your not breaking a car and wiring it yourself I think Dannycovin priced the Suby motor with wiring loom and ECU and it was going to cost 6k. Therein to build a covin to a high spec with this running gear is going to be an expensive build as there are so many items needed to make this work.
Stick to fitting the Suby motor into the current Covin chassis and running gear as it all works really well.
Regards Paul
PostPosted: Tue Jul 07, 2009 3:11 pm
Dreamer-Non Member
Dreamer-Non Member
Ok cool sounds like a plan..
So what will I need for the conversion?
do you have a link to this thread?
so subaru engine adapter plate for gearbox ecu?
anything else?
PostPosted: Tue Jul 07, 2009 9:35 pm
Go to my thread in builds and restoration for all your info on the build.
Regards Paul
