It is currently Thu May 24, 2018 10:08 pm
Post new topic Reply to topic  [ 5 posts ]
PostPosted: Mon Nov 25, 2013 6:44 pm
Has anyone got a flywheel that goes with the kit to fit a Ford CVH engine to a VW gearbox ( 200mm clutch )?
Teeth on flywheel must not be chewed, as mine have been.
Hope someone out there can help, or know where I can get one from.
Cheers
Vince
PostPosted: Fri Dec 06, 2013 7:49 am
I have not got a flywheel but I do have the bolt on adapter that goes on vw gearbox to obj engine.
Don't know if that's something you need?
PostPosted: Fri Dec 06, 2013 6:20 pm
Thanks for the reply. I have already got the adapter plus extended splines to fit the cvh engine to the vdub box.
What I'm after is the flywheel only.
Thanks once more.
Cheers
Vince
PostPosted: Sun Dec 08, 2013 11:01 pm
Hi re flywheel, if its the teeth chewed only can the ring gear not be replaced or is it part of the fly wheel ???? :smt020 :smt020
PostPosted: Mon Dec 09, 2013 12:42 am
Ring gear is part of the flywheel, hence can not replace.
Cheers
Vince
