It is currently Thu Feb 21, 2019 2:45 am
Post new topic Reply to topic  [ 92 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Sat Feb 28, 2009 2:29 pm
youll end up with more than a bad back with too much of that :smt003
PostPosted: Sat Feb 28, 2009 3:40 pm
I think not, at my age............
PostPosted: Sat Feb 28, 2009 4:14 pm
I was refering to sailing :lmao
 Post subject: re vals post
PostPosted: Sat Feb 28, 2009 10:03 pm
:smt012 that will be the new phrase for 2009" buggering on" i like it its so usable in many types of conversataion just try next time your out, :smt012 , buggering on , :smt012 :smt012
PostPosted: Sun Mar 01, 2009 11:11 am
I agree Money Penny, I've got a bad hangover today so I'm just going to be "Buggering On" with whatever I can :smt012
PostPosted: Sat Mar 14, 2009 9:50 pm
I've been playing with the doors this past week. I shortened and fitted one of the two and you know what, Val was right, it's working fine, no need for extra weight. It still needs fine adjustment and I haven't yet figured out how to install the motor but I'm happy with the result so far.
Panels needed removal of 1.35m.
Rest of the structure needed only minor modifications.
Inside view,
and outside. Not bad I say :smt007
PostPosted: Sat Mar 14, 2009 10:21 pm
Just the job Doros, looking good :smt012
PostPosted: Sat Mar 14, 2009 10:38 pm
Doros ,That looks absolutely fantastic.What a bargain youve had.They will keep your covin safe and sound :smt012
PostPosted: Sun Mar 15, 2009 10:16 am
nothing short of excellence mate :smt012 :smt012 i had no dought you would not just make them fitt but make them look so much better too, result i think :smt012 .
see you soon mate :smt012 :smt012 :smt003 :smt004 :smt004
PostPosted: Sun Mar 15, 2009 8:51 pm
Once you have the motor on, I wanna see a video :lmao :smt012
Covinless!
PostPosted: Sun Apr 26, 2009 10:38 pm
Well, getting the motors on was the real pain in the @$$. Both doors working fine manually but there was no room for the motor and rail assemblies because a concrete beam is in the way. After considering all the scenarios I could come up with, I ended with this:
The plan was to make a 5cm hole through the 25cm concrete beam. The motor assembly would be then mounted to the ceiling beyond the beam and use a 2.5m rod to connect the runner to the door. A pivoting point was needed at the end of the rod so a few rails and rollers were installed too. If this description is not clear enough, I hope the pictures explain the details.
25cm length, 5cm diameter.
That's the motor on the other side.
I tried a 1" pipe as a rod and after I saw it could handle the situation without any bending when pushing the door to close, I left it there.
That's the pivoting point with the needed structure. It seems I haven't taken any pictures of the other side yet (pipe to motor) :smt009
I also had to separate the control unit from the rail and also cut a bit off the rail as it was a very tight fit,
and also maneuver a sewage pipe around the rail.
A look from the outside. I've been dreaming of this picture for the last 13 years. What a feeling.
And you know how one thing leads to another, in order to install the motors and their ancillaries, I had to remove all the lighting from the ceiling. Also both motors need power and why not add a few more power outlets to the garage. Tomorrow an update on the new garage wiring :smt016 Off to bed now :smt015
PostPosted: Sun Apr 26, 2009 10:45 pm
Great job as always, looking really good thee Doros :smt012
