It is currently Sun Aug 25, 2019 7:18 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Aug 13, 2007 10:29 am
YOUUU NUTTER :lmao :smt119 MOST PEOPLE WOULD OF RANG THE SCRAPMAN LOL.YOU PUT THAT SHEET UP AS NOT TO SHOCK THE NEIGHBOURS REALLY DIDNT YOU :lmao
I BET THERE LOOKING OUT THE WINDOW SAYING WOTS HE UP TO NOW .I DONT KNOW HES GOT A BIG BLUE SHEET UP.I CAN HEAR HIM SINGING:smt007 "I LOVE RUST,YES I DO" :lmao
PostPosted: Fri Aug 17, 2007 11:21 pm
You could be right there Danny :lmao :smt007
Right, here we go..... Put in a few hours this week and made a bit of progress, but boy do I need some :smt020
Home made rear window frame now taking shape with only a few more bits to weld up where the rubber mounts onto lower edge.
Both side windows are now fully repaired and the roof has also been fully welded with just some filler/body prep remaining to be done there. I also replaced a section of gutter/roof which was in a bad way
The framework above drivers door is not looking to good though so I'll have to make some repair sections for this as well :smt013
Finished of the welding inside the Bus for side windows and main support sections
Starting to look a bit better now
Drivers front arch and lower section of door is rather rotten
Oh no :smt013 Not the dreaded Silicone repair again.... Why these idiots do this type of thing to floors and chassis I'll never know
There's only one solution when you see Siliconed repairs.... Cut the bugger out
Not doing to bad with the progress but I've just discovered some bad bits on the front chassis sections that will slow things down a little bit.
Still hope to have the drivers side completed next week with a bit of luck and then we can turn the Bus round to start work on the passenger side..... Oh joy :smt005
More to follow . . . .
PostPosted: Fri Aug 17, 2007 11:38 pm
Doing great job as always darren :smt012
PostPosted: Mon Aug 20, 2007 7:57 pm
Cheers Danny :smt003
Not much done over the weekend as I was at the VW Festival Show in Leeds. Good show but cold, wet and muddy :lmao Also had 80mph out my Bus on the way home :smt007
Right, back to the welding and grinding :smt005
All the rot was cut out the floor and old wheelarch, also needed to make a new section of lower door post as this had rotted out.
All fully seam welded
Gave it a light coat of etch primer for now
Almost completed the bodywork repairs on this side now so moving onto chassis soon
Just the upper door frame section to make now, should be fun . . . .
Had a poke about on the front chassis and there's a few places that require cutting out and welding but it's not to bad.
Hope to get this area done before RTTH show this weekend :smt019
PostPosted: Mon Aug 20, 2007 8:51 pm
Darren, is that your "but it's not to bad.", or a sane persons not to bad. Looking at your previous work, nothing seems to phaze you. I am quite sure that I would be welding it where it touched and using lots of filler. Keep up the good work, after looking at your camper at BSB3, and the photos on this site, your skills amaze me.
KEITHC (MEMBER No.256)
Lifes not always Covin, occasionally reality kicks in - All's not lost, the futures .pdf (pretty dam fine)
PostPosted: Mon Aug 20, 2007 9:41 pm
THIS BUS MUST HAVE RESIDED IN A COASTAL REGION TO HAVE ROTTED THIS BAD OR THE WATERS COME IN THE ROOF AND RAN ALONG THE ROOF SECTIONS?.DONT BUY A CAMPER WITH A POP TOP :lmao
 Post subject: re bond at his best
PostPosted: Mon Aug 20, 2007 9:42 pm
:smt012 well done there bond, its like youve done this sort of thing before matey :lmao :lmao :lmao sweet mate, just sweet :smt012 see you soon for :smt020 :smt020 :smt015 :smt015 :lmao :lmao
PostPosted: Mon Aug 20, 2007 11:28 pm
Keith.... When I say "Not to bad" I mean in comparison to the window frames :lmao I'll get some chassis pictures posted once I start on it, some is not to bad at all but other bits are a little more of a challenge. Cheers m8 :smt003
Danny.... I think a lot of the rot was caused by poor roof to gutter repairs in the past which leaked gallons of water inside :smt018
Money Penny.... You can't beat a bit of past experience m8, I think I'm starting to get the hang of this welding lark now :smt019 I'll be ready for a few :smt020 this weekend at RTTH though. I've just got a wee tweak to do on my Bus first :smt017 Cosworth engine anyone ? Only kidding m8 :lmao
PostPosted: Wed Aug 22, 2007 10:18 pm
Get that cossy lump fitted. Then you can cruise at 80mph :smt004
"Bikes are for speed and Covins are for posing"
PostPosted: Wed Aug 22, 2007 10:47 pm
It's all in hand m8, just need to get a few more resto's out the way first to raise the cash required for a wee Tweak in the Cosworth department :smt012
PostPosted: Wed Aug 22, 2007 11:44 pm
Got a bit more done but need to get things ready for RTTH show this weekend now :smt020
Started to rebuild the lower section of drivers door and straighten it all out again by making new internals to replace the ones that had rotted out, also made a new channels for the door seal. Door gap is not to bad considering how bad it all was :smt007
Rebuilt the top of the door frame which was a right pain to make, just needs a bit of filler to clean it up where weld and gringer marks are.
The drivers door now fits very well and closes much better
More to follow after RTTH show :smt020 . . . . .
PostPosted: Wed Sep 19, 2007 9:55 am
Not be doing much more to this Bus for a few weeks as I've got another project to start for a local Durham Dubbers club member. VW Type 3 Fastback for body resto and paint job, hope to complete this in the next few weeks and I'll start a new thread to cover the work soon :smt012
